5.3 BUILD LJ - Part 1 Boatside Rockers
Put a few more braces and gussets in today
I'm sure you are, but try and brace the fenders since you tied the stinger to them. The tub will buckle slightly with just bumping a rock into the tube fenders. My tj did without the bumper tie in. Jeep looks good
Thanks for the heads up! I didn't freeze the fenders to the frame at the bottom and then again at the top to the coil over mounts that are mounted the frame and then tied in with the crossmember... Then brace them at the front too so they are attached in three places I think it should be plenty strong!
Modded tire carrier to slight angle to match rear cage angle, added speakers and back seats...
Ok, these are never finished... but for the most part the winter build is over and here are the results!
