kensdodge1
Active Member
Installed 10 deg. wedges on the front of the power wagon sat. and found 2 cracked leaves in my 52" bastard pack 5.5 lift springs so replacement is needed. What i found was the stock dodge d150 rear packs have the same amount of arch as my bastard pack with 300lbs less spring rate. Is this a viable solution to big stiff expensive lift springs? Just wondering if they will flex better than lift springs?
