Sold/Expired 650hp sbf fuel injected
gomer pyle
SOLDgot a 351w bored and stroked to a 427. short block built by RPM in mt. juliet with moly 4340 crank, eagle H beam rods, forged pistons, and girdle. has procomp 200cc/72cc aluminum heads with a rocker girdle. kevko 8qt pan. 11.2 to 1 compression. rest of motor accessibled by mcmahann machine. comes with MASS FLOW fuel injection, fuel pump, regulator. everything needed to run. estimated by machine shop in the 650hp range. ran it in my EOR buggy up until i sold the buggy.
7500 for motor and mass flow
also, have a couple of built C6s if someone is interested.
located in murfreesboro, tn
might do some trading??
one is from nazir's single seater built by hughes. fresh go thru with one ride on it. full manual valve body. hughes converter. lokar dipstick. heavy duty case with extra ribbing
$600 (that's what i have in it)
the other is a stock rebuild with lower 1st and 2nd and 6 gear planetary. new converter at time of rebuild. built in 09 and run in my buggy
$300 obo
thanks the motor is nice but could use the cash right now
R they both for a small block c6 can u txt a pic of both of them to me @ 931-434-1047 thanks
