Aluminum vs Dom vs ? link bars
NTIDWELL
Since a lot of y'all have been running al links for a while which holds up the best and why al links look the most bitching but are they worth the money I know there is all kinds of different topics on this but I'd like to hear from y'all that's been running them any jackass can copy and post numbers and say well by this chart this is stronger **** that which is best for the money
NTIDWELL
Currently running 2"500 wall Dom wanting something stronger right at 44" long bars so would the 2.5 7075 hold up the best and who has the best prices on said links
JDodd
Murfreesboro
Call some machine shops in your area for probably the best price. With 2.5" 7075 it's probably going to be 800-900 after machining for 8 links
CCOR
706-559-9609
Athens, GA
I'd say the 4130 Chromoly DOM which is HEAT Treated with 1.25" heims is the strongest setup out there. I know he offers them in 2" x 0.25" wall and it is the best link out there in my opinion.
www.hereticfab.com
Later,
Bobby
gomer pyle
2" 6061 t6 will hold up unless you are a retard. I ran mine hard for 3 years and the rear bottom bars were only slightly bent
crawlin85cj
Barco Motorsports
Forney, TX
Re: Aluminum vs Dom vs ? link bars
I run 1.75" 7075 uppers in my race buggy and 1.5" DOM uppers in my trail buggy. I bent a set of 1.75" .250 wall front uppers in my race buggy jumping the rocks at DPG last year and went back to 7075.
If youre not a lead foot retard with no concern for your own safety I think DOM uppers are more than adequate.
Elliott
If you go aluminum go with 7075 there is a world of difference between them and 6061, and your talking long lengths with the dimm you gave is there anyway you could shorten them some? The shorter the stronger!
NTIDWELL
For sure going with only 7075 pretty sure I'll go this way cause al links are flashemifyougotem thinking 2.5 lowers 2" uppers With 1x1 hiems so it should have enuff meat there to keep the sides from splitting on the threads
Bigrocks4x4
Iuka, Mississippi
X2, 2" 6061 is plenty strong enough. Had em on my rockwell buggy with 450-500hp and 44"s. never had any problems ;D ;D
jmh78
Sale Creek, TN
My rear lowers are right at 40" so I went with 2.5" 7075 front lowers are 35" so they are 2.25 and the uppers are 2" 7075. WOD was the best price I found.
Cole
7075 is the only way to go on the lowers. Been running 2.25 lowers and 2" uppers since my buggy was built and haven't replaced one yet and I pretty much hit a wall at 20+ mph and didn't budge the link.
Here is what happens to 6061
ETO
In all fairness that's Scott's buggy and he could **** up an anvil with a freaking Q tip. :****: Man has mad skills at destroying ****. :flipper:
Elliott
Just for a reference it takes right at three times as long to cut a 2 1/4" 7075 as is does to cut 2" 6061.and the 7075 will squeal like a pig if you drill it to fast, freaking tough ****!! There is a big difference
crawlin85cj
Barco Motorsports
Forney, TX
Anything is gonna break, bend or get torn up with the right guy driving. All in all I've seen the best lifespan out of 7075. The only real problem I've had is keeping jam nuts tight. Now we soak em down with red loctite and I haven't really had an issue since. I would never use 6061, it's too soft. If you really wanna get fancy I think 7075 pressed into a DOM sleeve would be the best thing out there but getting it pressed in seems like it would be a bitch.
al1tonyota
Tuscaloosa, AL
I have 2-1/2" 6061 lower rears they are really long and when I get to beating on it they bend up I just pull them off from time to time and press them back strait ? My uppers are 6061 2" 1-1/4 rod ends on all of them! Gonna eventually replace the lowers when I quit breaking everything else :****:
Primary
HardlineCrawlers Assistant
Here are some related products that HardlineCrawlers members are talking about. Clicking on a product will take you to HardlineCrawlers’s partner, Primary, where you can find links to HardlineCrawlers discussions about these products.
