Jwhit55
- Joined
- Aug 19, 2008
- Messages
- 382
Any help will be greatly appreciated!! I'm running fox 2.0 emulsion coilovers on my buggy, so here's my question /problem. The lower springs on my front 2 coilovers are bowing and rubbing the bearing caps. Ive noticed about every other ride i need to tighten the caps due to this. Also, on the passenger side the lower spring seems to be getting into the shaft as well. The shaft has a groove wore into it which has caused the oil to leak out.
First off I'm not real familiar with these and from what I've read I know with the lighter springs bowing will occur. Is this a common problem with these shocks? Just seems to me that something isn't right about them. What can I do to prevent this? Thanks, Jamie
