Does anyone know if a 14 bolt axle stock has any type of caster if not has anyone had issues bending the spindle just noticed that both my rear tires angle in pretty bad I am tring to load pics but it is at least 1 1/2 in at the top??? Thanks
It would be less work to move the truss, mounts, gears to another housing.jccarter1 said:Some is from squat but it is still bent pretty good anyone have any trick to removing old ones and which aftermarket spindle seem to be the best
rednecklights said:You rough on stuff !
bee513 said:wheel bearing?
