s10truggy
- Joined
- Dec 16, 2011
- Messages
- 97
Ok I have a s10 on a fullsize 86 truck frame with a Dana 60 front axle and a 14 bolt in the rear I disc brake on the which are 80s model front calibers on the 14 bolt and regular one ton calibers on the front. My is that when I press the brake they low or the go just about to the floor they don't hold either I can pump them up and they just slowly leak some to the floor I done have a brake fuild leak I have a new master cylinders new lines I took the portional valve out the only is I am still using the s10 brake booster and master cylinder I have bleed the brakes three days in all row and also let the system bleed gravity style by cracking the right rear blessed for 30 mins can someone plz help with this brake issue
and I should
