Its NOT just any old IFS vented discs you use if you're working on a solid axle. Its FJ60 Landcruiser rotors, and either IFS calipers (one big one small piston), or the later "V6" calipers (two big pistons). Got my rotors at Napa for $17 each, application was an 85 Landcruiser. I just did this swap and my wheels no longer fit, Ill attach a picture. The calipers stick out past the wheel mounting surface.
Point of fact, the "V6" calipers are also on non-V6 trucks after 90. I have a set I got off a 94 4Runner with a V6, and a set of a 90 Pickup with a 22RE and they're identical, although different (bigger pistons) than whats on my 87 4Runner.
My brakes are now the LC rotors, "V6" calipers, stock 10" drums on the wide track rear (versus the 8" drums on the stock rear), 15/16" master cylinder, and a dual diaphragm brake booster. I haven't driven it yet, but I figure it should stop pretty well. A rear disc swap is in the works eventually after I finish the front end. Brackets are on the way. I just put the new rear end in before I tore down the front, so I haven't had time to mod it. Hell, I didn't even swap my geared and locked diff into it yet, haha.
~T.J.
