Blueleader
I'm fighting a wierd problem with my rig. Basically, it's 4-wheel disc with the chevy truck 1/2 ton calipers on all four corners, vacuum booster from a K5 Blazer, and a master cylinder from a later 70's vette (1 1/8" bore, I think). Wilwood adjustable prop valve in the rear brake circuit, just after the master cylinder. Dual Jamar line locks in the dash (I know... they suck. But they're not leaking). All four calipers and the master cylinder are fresh remans.
Front brakes seem to grab fine. Rears barely do anything. Currently, I have it up on jack stands with the wheels off. At idle in 1st gear (automatic trans), I can barely get the rear rotors to stop spinning. Pedal travel is a bit long, too. I've bled the whole system several times with a vacuum bleeder, the kind that connects to an air compressor. I'm pretty damn sure there's no air in the system. The prop valve is cranked all the way up and if I back it off at all, brakes get worse. Flex lines aren't all that old and appear in good shape. Push rod has very little to no pretravel.
Any thoughts? Maybe try a 2 psi residual valve in the rear line? I ran this same system off of a disc/drum K5 master cylinder before and it was much better than this. The rears still didn't grab all that great, though.
