brake ?
97f250
south
dont have good brakes really mushy and goes all the way to the floor i have a88 toyot with disk 44 front and 14 bolt disk rear and still running a stock master... is there a bolt on master that will help with braking or a boster and master i dont have to use tons of force just have to push them all the way down! and how do i eliminate the line that goes to the 3rd member on a stock rear axel.. i was told i could use a chevy master but it dont bolt on i looked on pirates and i seen brake upgrades but not for the set up i am running.. was wondering what other people have that work
are you running chev 1/2 ton calipers or 3/4 tons. there is a bigger toyota master with a 1" bore that would move a little more fluid. they are $130 if I remember right.
Put a chevy 1 ton master in it. You can buy the adapter plate from sky manufacturing for $30. I just did that same setup and it works great.
