zayne2427
There's only one way to find out
I've done a ton of reading on here and pirate, and got some good opinions from some good buddies that are much more knowledgeable on suspensions than I am. Trying to set up my coil springs. All the springs I have are either too short or too heavy so looking for opinions from the tech guys.
I have probably 10 springs in the 12'' and 14'' variety in various sizes from 150-400 if anyone needs some
talked with a buddy of mine and his rig (full body yj) is around 4250 lbs and mine 4 seater is 4750
his springs are
- front 175 over 200
- rear 150 over 200.
-another buddy suggested
front 125/200
rear 100/150
-Currently running Sway A Way Racerunner 16" remote reservoir coilovers. Roughly 8" of shaft showing at ride height
-Another buddy said since I have tender springs I could go
front 14-16" 125 over 225-250
rear 16-18" 125 over 200
Total Weight of Buggy using corner scales. This was before I stretched the front 3.5". Wheelbase now at 118.5
Front left 1277 Front right 1287
Rear left 1099 Rear Left1079
Ford hp 60 with double ended Ram amd rear 14bolt with Rockwell steering outers so a good bit of my weight is down low
Update 11/13/16
George @ Angry Fab let me borrow some springs
-Fronts are 16"-150 over 18"200
-Rears are. 16"-100 over 18" 150
Got them on yesterday and went and rode some private land.
Zero preload and ride height was still a little taller than planned but manageable
-8.5" front shaft showing
-7 3/4" rear shaft showing
-22 3/4" belly height
With any preload, it would put me taller than I need to be
. Ride was 100% smoother than the heavy springs that were on it but the body roll is definitely something to get used to even with a rear sway bar. Need to recheck my nitrogen pressures and see if i can adjust height there some. Will try and get some better measurements and get some opinions on getting this big ole girl dialed in a little better
his springs are
front 125/200
rear 100/150
Update 11/13/16
