Dana 44 front/ dana 60 rear
Gear ratio is 4.10, front has disc brakes. Rear 60 is a full floater with drum brakes.? i dont kno much about axles but i want to invest in some better axles for my k5.
thanks
edwin song
yes they will fit, so long as the spring pads width are the same on the rear 60, and you might need a bitch joint (conversion u joint) to fit the rearend. otherwise your all good,.
yea id like to get the dana 60 in the front an the 14bff in the rear, they are asking $450 fro the axle set. ive heard that the dana 44 and 14bff rear is a pretty good setup
thanks
edwin song
