D44 custom axle truss?
driving through a water hole at the ridgerunners jeepbowl. aparently it had broke before so it had been welded and they put that brace across the bottom, its on a chevy with 44's.
XtrmTJ said:
I am leaving them full width. Keeping them "alive" ? Is 39" too much tire ?
I have been running a 36X12.5 SS SX on the D30 (warn inners an outers and trussed) for years now.
As Karl said it really all depends. I have been told the same thing but I still built my D44. I am running a V-8 too w/5.13 gears & 35" tires. Might go to 36-37 tires but that is the biggest.
The u-joint you are running in your D30 shafts are the same as what are in your D44 and that will be your weak point. This is the main point of the D60. If I start having problems my plans are to go with the ARB 35spline & run D60 knuckles.
