XtrmTJ
I am swaping in a HP D44 and a 9" into mt Jeep. The 9" is simple to truss, but would like some ideas/pics of trussing a front HP D44. Thanks ! :clappy:
Pics would be great.
crash said:Unless you plan on jumping your rig your going to waiste your time. Plus if you are not carefull you will warp your housing....
KarlVP said:Not nesecarrily. I've seen a couple 44's that are tweaked and they haven't seen any airtime. Not "smiling at you" tweaked but enough to cause problems with a locker.
crash said:Then mine should have been bent :haha: :haha: :haha: :haha:
KarlVP said:Well I guess Hip farms bent 44's in his backyard.
I've seen two come through his shop that the housing was flexed enough to cause problems. One in his Neighbors YJ, and another in a Fullsize K5. And these guys don't wheel hard by any means.
XtrmTJ said:I am swaping in a HP D44 and a 9" into mt Jeep. The 9" is simple to truss, but would like some ideas/pics of trussing a front HP D44. Thanks ! :clappy:
I am swapping in the HP D44 for a D30. I will be running 39.5 " IROKS. I want to truss it for structural strenght. Thot, "I got it on the floor, what can I do to make it stronger." It is getting fitted with a Detroit, 5.38 gears, hi zoot inners and outers, and anything else I can think of to make it "BEEFY". Thanks for all the help/pics ! It will help alot ! So, you are saying, that for "normal" rockcrawling on a "light"(97TJ) rig, the D44 does not need to be trusses, it is strong enough as is ? Again, Thanks for all the input ! :beer:Jaydog said:Are you talking a truss for structural, or a truss for your upper control arms to attach to?
XtrmTJ said:I am leaving them full width. Keeping them "alive" ? Is 39" too much tire ?
I have been running a 36X12.5 SS SX on the D30 (warn inners an outers and trussed) for years now.
