G garner57 New Member Joined Jun 26, 2015 Messages 2 Jun 26, 2015 #1 I think I have a Dana 44 front axle, but the pumpkin is in the center. It does have a 10 bolt cover, and 6 bolt spindles. Does anyone no what axle I have
Jacobmc Well-Known Member Joined Jun 17, 2012 Messages 262 Location Wetumpka,Al Jun 26, 2015 #2 A pic would help
G garner57 New Member Joined Jun 26, 2015 Messages 2 Jun 27, 2015 #3 here is a picture front axle Attachments gg 001.jpg 29.8 KB · Views: 274
benfowler87 Well-Known Member Joined Jun 12, 2008 Messages 977 Location Jasper Alabama Jun 27, 2015 #4 Chunk is not in the center if it's right next to the leaf pack.
W wgamble Well-Known Member Joined Nov 9, 2013 Messages 411 Jun 27, 2015 #5 driver side, low pinion or high pinion? either an old grand cherokee axle (low pinion) or Ford (high pinion) with a spindle conversion
T Tater Well-Known Member Joined Oct 8, 2012 Messages 273 Location Hot Springs Arkansas Jun 27, 2015 #6 Not a waggy. It would be spring under with purch built into center, and oil filter would be more horizonal not vertical.
j-mox Well-Known Member Joined Sep 5, 2009 Messages 854 Location Missouri Jun 27, 2015 #7 Check the webs and look for a number. Should have Dana stamped in the web and numbers on one of the others to tell which model. 30, 44, 60
Y y2knole Well-Known Member Joined Jan 8, 2012 Messages 245 Jun 27, 2015 #8 all the info you need should be right here: http://bfy.tw/YCu
