Down and Dirty Transaxle Build
mtublazer2
OH
Posting the bulk of this for ZJTrey.
Here's some of the details...
L67- SC 3800 V6
Factory transaxle 4t65e
Axles:
Chevy Dana 60
4:10 gears
Grizzly Locker
Chromo shafts
TMR kit plated knuckles
PSC 2.5x8 DE ram
PSC 7.3 cu in/rev orbital
Artec arms
Nitro joints
Yukon drive flanges
Custom Full Truss
14B custom passenger side offset for tcase alignment
Shaved
4:10's
Grizzly locker
DE chromo axle shaft
Drive flanges
Custom truss
Divorced 205 case, 1350 drivelines, 2 piece rear shaft
1.75" uppers with johnny joints, 2"x0.25 wall lowers with johnny joints.
1.75"x.120 wall chassis w/some .090 wall and 1.5 dom
Profender 2" body, reservoir coilovers
40" Stickies of some flavor on beadlocks
CNC brakes dual masters, single pedal 7/8 front, ¾ rear.
Corbeau Baja XP seats
Winters shifter
114 wheelbase
Shooting for a 19-20 inch belly
14 Bolt
Shave:
D60
Output of Transaxle - Will be connected to the divorced 205 via short intermediate shaft
Starting on the roofline
B pillar work
Plated knuckles
Looking out from the behind the seats
f
Front CO's
Lookin sexy
More chassis work
Protection for the grease zerks
Pulled the 60 to get it finished up.
Ram behind the axle, artec arms.
This gets us pretty much up to date.
Lookin good!
How are you using the transfer case? It looks like you have one transmission output lined up with the rear axle and the other transmission output lined up with the transfer case. Are you just using the transfer case to disengage the front axle? Or are you going to weld the differential in the trans and only use the trans output thats lined up with the transfer case?
diff is welded in the trans.. using the front output to turn the transfer case and ill have a two piece driveshaft running to the rear end.. the divorced 205 is sitting backward in the chassis..
Thanks Guys…
The transaxle and motor fit basically in a 30x30x30 area..
I'm mainly building this for a trail rig but theres a chance i'll do a little racing in it..
