patooyee
- Joined
- Sep 27, 2008
- Messages
- 5,692
Here's that video I was talking about. He did it with a 4l80 but like I said, its all the same crap at the transmission.
4l80e full manual with no computer
Here's an excerpt from GM's 4t65 performance build book:
"An easy and cheap way to shift the 4T65E is with two toggle switches. The toggle switches need to switch ground to pins A and B in the pass through connectors. To operate the transmission turn both switches on. This will put the transmission in 1st gear. To shift into 2nd gear shut off the switch to solenoid A off. To shift into 3rd gear shut off the switch to solenoid B. For 4th gear turn the switch for solenoid A back on.
SHIFT CONTROLLERS
TCI and CompuShift offer automatic shift controllers that will operate the 4T65E Transmission. These are excellent choices for street strip applications. An inexpensive alternative for drag racing and occasional street use is the MSD Programmable shift controller part number 7559. (Fig. 234) This controller was developed to shift a Lenco type transmission. With a little ingenuity it can easily be adapted for use on the 4T65E transmission.
Two relays are needed to convert the system for this application. The MSD controller needs two inputs a: Launch / Reset and Shift Override. The Launch / Reset button resets the controller to first gear both in electrical outputs and in the shift sequence. The Shift Override button manually up-shifts the controller. In first gear the controller does not output a signal. When the 1-2 shift is made it turns on a 12v signal. When the 2-3 shift is made another 12V signal is turned on. Since the solenoid needs a ground to activate, relays are needed. Ground should be connected to the input of two relays. The Normally Closed output of the 1st relay should be connected to pin A on the transmission pass through connector. The normally closed output of the 2nd relay should be connected to pin B of the transmission pass through connector. One side of the coil of each relay should be connected to ground. The 1st shift output from the transmission controller should be connected to the other side of the coil of the 1st relay. The 2nd shift output from the transmission controller should be connected to the other side of the coil on the 2nd relay. The normally open side of the relay can be used for gear indicator lights. Two lights can be connected to power and the other side of the lights connected to the normally open side of the first and second relays. When the transmission is in 1st both lights will be off, in second the 1st light will turn on and in 3rd the second light will come on.
• MSD Programmable Shift Controller PN 7559 (Fig. 234)
Here's a link to the book itself:
https://drive.google.com/file/d/0B1XdiIKdc8_AM1RlVndDS1NkTFE/view?usp=sharing
It was published back in 2004 or 6 I believe so some of the info and part numbers are a little outdated.
SHIFT CONTROLLERS
