snowgoon
Ok so I am putting dual cases in my toyota. Do you have to move the support to the back case? Whats best? Any advice? Thanks
This :awesomework:....If you can swing it, pick up an aftermarket dual case crossmember and run two t-case mounts....or IF you're good at fabbing, you could build one...If the engine is in the stock location and you didn't swap the trans to one that is different in length, then no you do not have to move your crossmember. What would be better is an aftermarket crossmember / skidplate that is designed for dual cases. :awesomework:
dont get all pro, seen them crack/break. Ive also seen alot of "custom" cross members from my "Pee brained" buddies :haha:. If your going to fab it, do it good. id go with marlin crawler's
Pop over here and give Odie a call
I posted in his tread he has yet to answer me.....
