ECM/PCM- Jeep
jeepermc
Wet side, WA
I had a friend of a friend ask if a cherokee ECM would work on a wrangler of the same year? I don't know the answer... Does anyone here? Both are 95's. My guess is no?
I can tell you that the spare 4.0 5-speed ECM from a '91 cherokee worked in my '91 4.0 5-speed wrangler... I think if it's the same year/trans/motor you should be fine....
The only difference between the an auto and manual PCM is the NSS ground. Other than that I've run both tranny types on the same PCM.
