tommy450r
Ive got a 01 2500hd with the new style 14 bolt in it what all carriers will fit in it like will the old style fit??
99BLUEXJ said:well i'm not positive but the little bit i have saw on them i think people were saying the housing was the only difference and everything inside was the same. its been awhile since i've saw it mentioned though. i'm sure there will be some others that will chime in, lets see what they say
irondalefj80 said:its a semi-floating, if it has an axle that bolts in where the wheel lugs are, its a semi.
i have a semi-floating 14bolt axle in my garage, i took it in on a trade, thinking it was a full floating....
it's a good boat anchor, the only 14 bolt with a 10.5" ring gear is the semi floating. the full floating is a 11.5". the 6.0 can have the 11.5", if the truck is classified as a 2500HD it has a 11.5, reguardless of what engine, if it is a 2500, it is a 10.5".
TBItoy said:This is so ****ing incorrect it's not even funny...
9.5" 14 bolt is Semi-Float
10.5" 14 bolt is what "everyone" runs, and is found it the 6.0 2500HD
11.5" is a "new" AAM axle that is in 8.1/Duramax/new Cummins trucks.
Tommy knows what axle is in his truck.
your axle will use any 10.5 diff. They didnt change the diffs, just the outer casting/added discs.
irondalefj80 said:Just repeating what I've heard and what I drive.
I believe the pinion support housing is also different in that there is a different mounting pattern on the flange between old and new housings. I'll see if I can find where I read that...TBItoy said:This is so ****ing incorrect it's not even funny...
leeman1790 said:WTF. Totally incorrect. Full float the axle is bolted to the hub. Semi float the axle is held in by c-clip.
Diesels and 8.1 are the only ones to get the 11.5 aam axle. It has no pinion support/removable pinion like the 10.5 has.
2500HD's w/ 6.0 have a 10.5 with removable pinion just like most 14b's that are in Offroad rigs.
2500 non hd has a semi float 14 bolt(9.5") and 1500HD has same axle.
tommy450r said:Well I got a older style carrier an it fell right into place f ixed all my problems thanks for the input lol... now I need a t case turns out a hd hates bouncing haha
