TacomaJD
I LIKE CHEAP STUFF.....
TBItoy said:I looked up parts to do the conversion, looks like about $100 per shock (plus springs)
Got any quick links to the parts needed to do this?
TacomaJD said:Got any quick links to the parts needed to do this?
TBItoy said:Nah I just looked on Poly Performance, they have all the components of each type of shock http://www.polyperformance.com/shop/2.0-Coilover-Air-Shock-p-1-c-3794.html
The only part I'm skeptical of on the parts list is the lower eyelet.
Coilovers vs Air shocks used different lower eyelets, and I believe poly has the wrong ones listed for the "2.0 Coilover Airshock".
Since they use an air shock shaft, they would have to use an air shock lower eyelet.
The lower spring retainer may nest on the air shock eyelet just fine, but I'm not 100% sure what parts they use as I've never seen one in person.
TacomaJD said:Been reading into this. How exactly do you determine what length coil springs to buy (upper/lower) My 16" air shocks are 39.6" fully extended and 23.6" collapsed. Was just looking at things I'd have to buy and realized that I'm not sure exactly how to gauge what length coil springs are needed. Yea, another newbie question.....bc I'm good at being a newb lol.
TBItoy said:rule of thumb is lower spring 2 inches longer than shock travel (so the dual rate slider doesn't fall off the shock body at full droop), then upper spring equal to shock travel (so you have a spring stack that is a length that falls into the threaded pre-load adjustment range)
Neal3000 said:Plus machine work
tiny said:I don't think you need a lower eyelet. You will need the lower spring seat, which is a separate piece. The seat may be different than the 7/8 shaft seat, because of the bigger shaft.
TBItoy said:That $100 estimate included new threaded shock bodies, but didn't include lower eyelets. (I also assumed you could get the parts for 10% less than Poly Performance, as they are kinda high on stuff)
Neal3000 said:If you go through poly's vendor on pirate you can get WAY better prices on fox stuff with free shipping than what their website shows
It seems like it would be easier and maybe about the same money to just sell your airshocks and buy some used coilovers
tiny said:Most of your body roll problem is the way your shocks are mounted. They are angled in too much. If you mounted them strait up and down and tuned them, you proly would need the coils.
Rokcrler said:I told you that the first time we rode jackass.... then i pointed out that the rear frame section would have to be cut to clear them straighter...
TacomaJD said:NEEDS MORE TRIANGULATION!
pachary said:You can run a very small amount of N2 pressure, tune like a normal coil over, then add N2 as needed.
If you put substantial N2 pressure, the "air spring rate" rises very quickly as shock compresses.
zebrajeep said:All N2 does is raise/lower ride height. You tune the "progressiveness" by adding/subtracting oil.
All other aspects of tuning are the same as coilovers using spring choice, crossover setting and shims.
