rockkrusher
does anyone no if a yota factory power steering pump will work for single ended ram full hydro
Rjhoward32006 said:I know someone that runs a 2x6 single and another that runs 2x6 double ended ram with a stock pump.
There is a mod to make it flow faster or something. You can research on pirate.
I have factory pump and it has worked but it doesn't do great at idle mine is a 2x6 single ended,I just ordered a 1650psi pump from trail gear $219.00 comes with pulley and the headache will be gone before it starts imorockkrusher said:does anyone no if a yota factory power steering pump will work for single ended ram full hydro
muleskinner said:I have factory pump and it has worked but it doesn't do great at idle mine is a 2x6 single ended,I just ordered a 1650psi pump from trail gear $219.00 comes with pulley and the headache will be gone before it starts imo
i am gona try itbillstoy said:I took the restrictor completely out of mine. I have a 11 ci orbital with a 1 1/2 X6 ram steered so fast one turn lock to lock like a gocart I put a 2x6 ram on it to slow it down ! for 2 years my pump whines when turning . no cooler and never gets to hot to touch turns slow at idle but it's a buggy how often do you turn at idle? I don't . Works well for the price!
