jasper
If someone could explain to me what the difference between a regular full manual valve body and one that has engine braking. Is the engine braking even needed?
jasper said:If someone could explain to me what the difference between a regular full manual valve body and one that has engine braking. Is the engine braking even needed?
jasper said:I may have screwed up today and ordered the one with the engine braking. Now that we've talked about it. It may be comparable to a Kubota sxs we have at work. Let off the gas and it's like laying on the brake. That would be nice down hill but suck everywhere else.
infamous1 said:I put a manual with a brake in my buggy with this last trans and I hate it. When "testing" a hill, like running up on it light throttle before the real assault you have to knock it into neutral or it kills the engine. When cruising down the access roads if you downshift or stomp it and let off it will drag the back tires violently. Yes downhill its OK but not enough to make me want to deal with the other peculiarities of engine braking. If it wasn't such a PIA I would put my old manual VB without braking back in.
X2 my buggy has it and the only time it seems harsh is down shifting from second to first. Besides that it's smooth and doesn't affect the engine at all.patooyee said:Something is wrong there. I've had 2 rigs with engine braking and neither killed the engine when I did that.
Elliott said:Does it put pressure on the reverse gears to do the braking or what?
infamous1 said:Its a TH-350 trans, same stall as last setup just freshened up the clutches, rolerized, and added the "mandatory" RMVB with 1-2 braking. Works good crawling and killing just not in between. If I hop up on big hills in 1st and roll back it off will actually kick the engine over backwards and spit through the intake. I just neutral bump it now but occasionally I still forget. And the 2-1 downshift is brutal if you forget its a reverse VB under full throttle looking for 3rd haha.
