RustyC
- Joined
- Dec 15, 2010
- Messages
- 1,251
Does anyone know of a front sump oil pan for a one piece rear seal GM 4.3L?
I have a 4.3L in a rear engine buggy and I am having oiling issues. Looking to keep a wet sump. If I went to a dry sump $$$, I would just swap the engine style.
Basically lost oil pressure during a uphill beatdown. Either the pickup was no longer submerged in the current rear sump pan or most of the oil was pumped to the top of the engine and could not drain back fast enough. I made it up but the engine is hurting. It was 1 quart over full when this happened=rod knock.
I have a 4.3L in a rear engine buggy and I am having oiling issues. Looking to keep a wet sump. If I went to a dry sump $$$, I would just swap the engine style. Basically lost oil pressure during a uphill beatdown. Either the pickup was no longer submerged in the current rear sump pan or most of the oil was pumped to the top of the engine and could not drain back fast enough. I made it up but the engine is hurting. It was 1 quart over full when this happened=rod knock.
