Thanks
what i was told is if you just drill out the restrictor it is an easy thing to do to help with the steering dos it really make a diffrence
and from my experiance ya better have a couple spare pumps if ya drill out the restrictor...That has nothing to do with your steering box. That is modding your pump.
ya think a good external cooler would help at all Bill?? Or were you running one and still burn em up?and from my experiance ya better have a couple spare pumps if ya drill out the restrictor...
if you drill that resrictor out it will work a little better but the pump will go out right at the worst time & place, Ive seen it twice its a pain in the ass when you have to do it in the mud when its dark Trust me
5+ years on the same junkyard pump 3 of that with full hydro. Drilled restrictor completely out and shimmed the relief valve. Not a problem at all. Guess it helps that I run a cooler and a ginormous reservoir.
Mo fluid = mo betta. these had stock res. both on different trucks tho:wtf:
