smitty0u812
- Joined
- Feb 7, 2011
- Messages
- 50
I'm wanting to change over to a ls but just wanting to know what is a good cam to run in one to wake it up and who dose real good tunes thanks
RebelRider said:You need to be more specific of your intentions. Will this be a 6k rpm hill killer or a low end crawler? Some cams make their power low/mid range and some way up high. If you are going low and slow, you will not want a choppy cam thats makes it's power up high in the RPM range.
Tick performance, good, talented folks. Located two miles from my house.Mortalis5509 said:Tick performance. They also dyno. They built me a 416.
How does that cam do just crawling? I seen they also had a 1200-6200 range also. Try to find a middle ground for hill Killin and crawlin. Thankspholmann said:X2 ^^^^ what he said. If you do change the cam, plan on spending some money on a good solid tune. My personal recommendation is the Howard's camshaft I'm running in my lq9. It has a power range of 1700-6700 rpm. Also don't get any canshafy over a .550 lift. The flow numbers start backing up after that amount of lift. Anything more and your just abusing your valvetrain. Also under .550 lift you can run the cheaper gm performance ls2/6 valve springs.
Cam: http://www.ebay.com/itm/111849918783?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Springs: http://www.ebay.com/itm/261387093427?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
pholmann said:ill tell you how it is tomorrow. I'm going for shakedown tomorrow.
Thanks pholmannpholmann said:I can answer your question now. It's smooth as silk crawling. Makes more then enough power down low. No surge or anything crazy. I like it.
