popcancherokee
I have a 1991 jeep wrangler and put a good working ax15 in it about 6 months ago put in new clutch at same time.worked great then about a month later slave cylinder started leaking so put a new one in.it worked OK for a short time now some times it works great.and other times it is a bitch to get into gear all the gears.the clutch seems to almost goes to the floor before it works.changed trans fluid twice and bleed the clutch allot.could it be a bad master cylinder.It sucks when your half way up a hill and back up and then cant get it into gear.Thanks for all info...
