Jon Piper
So my wife calls me at work Friday night and says the jk is making a terrible noise and she is calling her father to come pick her up. So I go put it on the trailer at 3:30am pull it home and get to work.
I expected a stuck caliper or something similar but after getting it on jack stands and pulling wheels/ calipers etc I see the pinion moving in and out. I figured pinion bearing took a poo. Now I installed a set of g2 5.13's in this unit roughly 64000 miles / 4 years ago.
Pulled diff - got the pinion out in my hands and the bearing was not bad. The teeth took some abuse but very little damage from what could have been. I pressed a new bearing on re-torqued the nut and checked the pinion pre load all seemed ok , the pattern was "ok" gived the situation. Filled up with lube and she was fine...
So, when I have an issue I prefer parts to fall out on the floor. I like to know what caused the issue. I could understand a crush sleeve problem happening early in life or even a pinion but backing off but seriously taking 60,000+ miles and 4 years ? I'm likely to order a new 5.13 and master install kit just to satisfy my curiosity alone with a solid spacer for the pinion.
Has anyone else encountered a similar issue ? Would y'all keep on rocking the r&p like it is ?
