GaryTJ
There are quite a few wanna be mechanics out there.
Lets see how good you are. No help from the professionals now!
These are basic questions I would ask to see if a person even qualifies for a real interview.
1. What does an E.G.R. valve do? Why is it necessary on today’s vehicles?
________________________________________________________________
2. Explain the reason for the A.I.R. system on modern vehicles, describe what it does, and what components make up that system.
3. What is an OBD readiness monitor?
4. What does the EVAP system do and how can you test for a problem with that system?
________________________________________________________________________________________________________________________________
5. Which of the following can NOT cause a cranks/no start condition on a fuel injected engine?
May be more than 1 correct answer. Circle all possible causes.
Spark Plugs Timing belt MAF Sensor Ignition Coil
Starter Motor EGR Valve Fuel Pump Oxygen Sensor CKP Sensor
6. What is voltage drop? Explain how to test for it.
7. A car comes into the shop and has a p0301 code. Circle all the possible causes.
Spark Plug Timing Belt MAF Sensor Ignition Coil
Starter Motor EGR Valve Fuel Pump Oxygen Sensor CMP Sensor
8. What is the most likely cause of a p0440 code?
9. A car is towed in for a no start. A technician checks it out and says it cranks ok but will not start. What should be the first 4 things checked to narrow down the possible causes of the no start condition?
10. A Fuel injected vehicle is brought in and has a miss at idle on 1 cyl, but it runs fine over an idle. Power is fine and fuel economy is fine. Compression checks OK. What is the next thing to check and why?
________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________
