I used Aukeen driveshaft ( (253) 395-0392) in Kent for my Ranger after a doubler. Fordzuki helped me do the front shaft though. For a front I'm not worried about the vibration, but for a rear, I'd use Aukeen again in a heartbeat.
I don't recall a price, but I know he used thicker walled material than a factory shaft.
Make your own.......
Scroll down to Tech write ups/How to's. There you will find D I Y how to drive line good luck. ( CHEERS):beer:
the place in yelm is advance(d?) drivelines. Ive used them once and it was spendy, having dlines made always is...
Since them ive done them all myself. It isnt that tough just take your time, plenty of write ups on it throughout the interweb...
Last time I looked into getting a shaft made I called around and was finding the same $400+ or so for local. On a whim I dropped the 'onetoncv' (Jess IIRC, can't remember his actual shop name) guy off Pirate a PM and was vary much surprised when he came back with something like $200 or $250 SHIPPED to my door. All USA parts (or as much as he could) I think as well (not that that matters a ton to me). I ended up finding a used shaft that worked for me, but it was a big enough difference that if I had the time I would hit him up again.
That was 2 or so years ago....
If you are starting from scratch a fair price would probably be $450 with all new parts... if you sourced parts and just had it made it shouldn't be more than $150 with .120 wall dom. That's what I charge people.
It depends on how your suspension is set up. The front of my leaf sprung Toyota uses all of the 10" slip. My buddy did a sas and put the shackles in front like a Jeep and it only travels a few inches.
If you make your own, take your time. My first one i thought i had everything lined up. The slip side turned out perfect but the non slip side was off a hair. Couldnt hardly feel unless goin 25 and over so i figured it be ok. Couple weeks later i needed a new bearing for the output shaft on the t case. I then remade my drive line and took my time. Never been balanced and cant feel it goin over 50.
The rear dont use nearly as much slip as the front due to the diff being center (im assuming your rear diff is centered). I run the stock slip in the rear for a yota and have never had an issue. It only uses about 3" of the shaft and i have a good amout of articulation. But i run leafs. My buddy runs links front and rear and he has a stock yota driveline. Has never pulled out.
looked there but thats just for a ssquare dl?
