LS oilpans what are y'all running?
race_jeep
Tuscaloosa,AL
I've got the ls1 oilpan for my 5.3, but i started reading about oiling issues, so I thought id ask what yall are running? :afro:
I run a Kevco, it seems to work really well and I always have good oil pressure.
from what i've read, most are running the kevko pan or an acumulator, if not both. i recently picked up a kevko pan for my 6.0, i'm gonna use it b/c it seems to be proven.
psc sells a baffle setup for the f-body oil pans if you happen to have one.
Kevco still leaves some to be desired. MAST came out with a new pan but its pricey and still doesnt fully solve the issue. Accumulator is a must, Kevco, or a modified LS6 pan.
I've got an LS6 pan for sale, but its not modified.
i put just a stock 5.3 pan on my ls1, i have ran it that way for 3 years with no problems.
I have been happy with my kevko. You can get the fittings in any position u want and it is priced well. It is the best bet if clearance is tight. The dipstick with it is junk, so get a new one or use stock. Eor sells the moroso pan also. It is nice if you have more room.
I used to still lose pressure pretty fast with the Kevco, it wasnt instant like the stocker. I believe Blase had the same experience. Just saying dont buy the Kevco and thinking you are 100% fixed.
I have not been upside down with new motor, but have had it up and down Viagra, wailing wall, and a few other steep obstacles and the psi has never even budged. :dunno:
Maybe I am just lucky??? :woody:
Or just that damn good! :flipoff1:
This..... or some derivation of....
Start with this
End with something along these lines even though this one isnt finished.
No you are just that good. Upside down it dont matter. Even an Accumulator is only going to buy you a second or two upside down. Its steep forward and on your sides that you are compensating for. Steep rear should really never be an issue with a front engine buggy with the pickup at the back of the pan.
I want to add that I am in no way discounting what Wyatt said about an accumulator. He has way more experience on his side and lid than I do. :****:
I have had good luck with the pan alone, but have not put my new motor in near the conditions Wyatt has with his old buggy. So, I will agree that if you have the money and space, an accumulator is a good idea.
I have had good luck with my Kevco and keeping good pressure. As long as you hook the lines up right to the filter you should be good ;D
I have had good luck with the last two buggies running the stock ls f body pan and the Improved racing baffle kit. I also run a little extra oil in the motor just to help. have not seen a negative to running a little extra oil in the motor...
