Mini spool or full?
skipnrocks
Billings Montana
I'm building a kids buggy 200 hp with40 in stickies. Are these 35 spline mini spools worth a darn or should we only do a full spool. Just want reliable. We do some ledges that need bumped.
And if full spool is the only way then if I have a full width ford 9 are all the stock center sections the same or do some have larger bearings.
I broke a couple of mini spools and cross pins in a 9" with a 4 cylinder jeep motor turning 38" boggers. I would do a full spool or locker but I will not run another mini. And there is different bearing sizes in the carrier.
There are several different bearing sizes in a Ford 9" you will read the terms big bearing or small bearing ends. This is referring to the semi float wheel bearings that press onto the axles shafts and support the vehicle at the ends of the axle housing.
Then there is the the carrier bearings in the third member that is seems like you are questioning. Most oem third members had carrier bearings with 2.892" o.d. and 1.625' i.d. where the bearing presses onto the spool.
The aftermarket developed third members where the carrier bearing o.d. is 3.25" and the i.d. is 1.781" on the spool side.
The bigger bearing third members and bearings allow for a bigger 35 spline spool.
The o.d. of the 35 spline axles shaft is 1.5". The o.d. of a mini spool or 35 spline aftermarket spool (made to fit in a stock third) is 1.625. That is not a lot of material left between the bearing and the shaft. It can be assembled with an stock third and 35 spline spool but will be a lot weaker than moving up to a 3.25" bearing third and big bearing 35 spline spool.
These are the costs of getting a 9" strong. I can be done and works well. It is almost easier to have all the parts delivered to you door and built vs sourcing an axle to modify.
Fab housing, nodular third, pinion bearing retainer, spool, gears, shafts and full float ends are the icing on the cake. BUT costs more than a 14 bolt. thumb.gif
ForMud said:
Okay a dumb question.....What's the differences between the two? I thought a spool was spool.
Full spool replaces the carrier. Mini-spool replaces the spiders. Like the difference between a Detroit and a Lock-Right / lunchbox locker.
I ordered a full spool. Another question I have is the third member have a symmetrical bolt pattern? I know if youbmijnt one upside down it changes the rotation. That's not my question. Since the housing has a slight offset and so does the third I was hoping to use that to my advantage moving the yoke further one direction.
