Ok not sure where to how to start this..
`1. is there a fuel relay some where on the truck and where would it be?
2. this is 22re 85 truck
3. so i turn the key on and check all fuse for power w/ a test light all fuses
show power except the efi fuse.
4. go under the hood check all fuses and all show power w/ test light.
5. but no power to the fuel pump plug, at the tank..
traced the wires to a grommet under pass. seat pulled trim and carpet back and checked the plug there no power???
so i pull fuel pump out of the truck and test it in a bucket of fuel and it works just fine.
So the main plug under the seat runs up under the pass side plastic cover where the motor control box is some wires go to the box others run on up and possibly into engine compartment.
Is there something i am missing? such as another relay by glove box compartment, or could the control box be bad ???? I'm stummped
any input or help would be great..
thanks :awesomework:
