Jhouser
Has anyone used Nylon brake line on a crawler before? How did it hold up. Also what size An line do you use for the flex line -3 or -4 or does it matter? Thanks, Joey
I was talking about a flex line like a rubber on stainless line between the chassis and axle and from the axle to the caliper. I did not know how flexable the Nylon is if you could use it for everything or if you needed something else. Thanks for the info i think i will give it a shotInDaShop said:A lot of people run them now. I know my buggy wasnt the first out there with them, but it was one of the first on Hardline to have them.
I never had a problem in 3 years (no longer a buggy owner). Only two leaks, one was when I dropped the caliper and pulled the line out, and one when I backed into some serious brush and a limb reached in and bent my right rear over creating a pin hole leak.
Not sure what you mean by flex line. My entire brake system was the nylon line. I ran all Nylon from the Wilwood Mastercylinder, through the cutting brakes, down the links, and across the axle straight into the calipers.
At the caliper drilled and tap the inverted flare out to a 1/4" NPT and then use a 1/4 NPT to 1/8 NPT adapter. Then just screwed the supplied fitting right into the caliper.
Do you have the nylon running down the link bars or a braided line from chassis to axle then more nylon out to the wheels an another braided to the caliper.bigsilly said:My last rig and my current rig has it. It is tough. I have stainless braided running to the caliper like you are talking about.
Jhouser said:Do you have the nylon running down the link bars or a braided line from chassis to axle then more nylon out to the wheels an another braided to the caliper.![]()
I did the same thing at KOH when we were doing front end work on the buggy. Super simple to fixInDaShop said:Only two leaks, one was when I dropped the caliper and pulled the line out
3-4 years and never broke an ARB line that I recall. The stuff is pretty stout.72dozer` said:save the promblem of broke brake line on the trail. i would run steel line everywhere except at each link and each caliper run braided there. i looked at the nylon line but think anout how many arb lines get tore off or broke its pretty much same deal in my opinion i think it just a a bad idea
Bones said:- Help me out here....what are some other cons?
