Project Big Blue
brokenparts
Hillsboro,OR
I dont post a whole lot over here but I reconize some of you from other boards... Anyway, here's my build:
When I bought her...
Added a toybox and some 36s
Couldnt leave well enough alone...
Decided to get rid of the stock tranny, wanted lower crawl box gears, more flexy lift (SOA), bigger tires 39.5 Iroks, dual battery's half doors, sliders, fender trimming, Front/rear arbs, hydro assist... etc
Dual battery:
Hydro assist:
Fender trimming
thanks... now I got to do the other 3 doors! I think that the cup holders up there make more sense than putting them in the middle of the door like you see a lot of guys do.
actually I decided to go with a different steering ram than the one pictured. That one sucks because the attatchment points would not have allowed any movement... I went with this one from Surplus center..
SWIVEL BALL END CYLINDER
Brand new, welded cylinder with wire-lock gland retainer. Swivel ball joints at both ends allow for angular motion.
SPECIFICATIONS
* Double acting
* Bore x stroke 1-1/2" x 6"
* PSI max. 3,000
* Rod dia. 1"
* Ports SAE 6
* Retracted length 13-1/4"
* Shpg. 7 lbs.
END MOUNTINGS
* Rod end swivel-ball
* Ball width 1"
* Ball O.D. 2"
* Pin hole 0.75"
* Base end swivel-ball
* Ball width 1"
* Ball O.D. 2"
* Pin hole 0.75"
