crawler nut
- Joined
- Dec 25, 2010
- Messages
- 701
Hello everyone, I just took my rig out yesturday for the first shake down run, an wasnt running real good from about 1000-2000rpm. It is a chevy 355 flat top pistons, 58cc heads etc. Accel HEI distrib, Accel wires on Propane. It also does not have a steady idle. If you are watching the tach, it will be up an down 100 rpms or so. It hesitates between the rpm mentioned above when it is under a load an when you really mash on it an gets warm it will pop or back fire. Not all the time just on accasion. Any help would be greatly appreaciated. Do you think it is fuel or fire? Thanks
