Sold/Expired Propane stuff
We can supply new parts if you need them. If you are looking at used parts be careful with 425 mixers. The housings can get worn out and there is no repair for it. A good way to check it is to see if the air/gas valve can move sideways in the housing. If you can see it move then the housing is worn out. There is only about .002 clearance between the air valve assembly and the housing so it is almost impossible to see side movement in a good mixer.
I'm asking for a friend, he's trying to be as cheap as possible. But could you PM me the price on new stuff?
