shotmobile
After a little bit of research I found that my Grand Cherokee came with a master cyclinder bore size of 1.0625". Now I looking at replacing it and I have to options.
First one is a master cylinder out of a 2000 Dodge Durango. It has a bore size of 1.125" or 1 and 1/8"
The second one is out of a 1998 Dodge Ram 1500, 2500, 3500. There all the same. It has a bore of 1.25" or 1 and 1/4"
These are the options I leaning to because they have the correct port fittings of 10 and 12 MM.
Now with my set up I have the Factory Ford Dual piston front calibers and the rear disk brake set up on the 14 bolt are Large (2-1/2" Diameter) single pistons calibers. So what I was thinking was going with the Ram master cylinder (1 and 1/4" bore) because of the large calibers. Does anyone see any problems with this?
Thought, Ideas, Suggestions wanted....
