rear brake drum
cexodusk
Member
rear drums on 83 toyota, just bought it. The ebrake cables are snapped. On the driver side drum, on the side clostest to the leaf spring there is a lever where the ebrake cable hooks onto (not inside the drum on the outside). This is all fubar. Can you get these from schucks or do i need to go to pull a part
I might have an axle assembly you can have. Ill have to look and see if I still have it.
I took my setup out completely, and ran a micro-lok (hydraulic linelok); I've probably got a couple of those fulcrums kickin around...
