Rear disk brakes on tow rig?
CrustyJeep
Brewery
I'm considering doing disk brakes on the rear of my 1/2 ton GMC tow rig, using weld on brackets and GM front calipers. I know jobless did it to his old Ford tow rig, and I now demand that he post up his impressions :D Anybody else ever done this or have thoughts on the matter?
I always wanted to try it on my old highboy with the same chevy Calipers. But it already locked up real easy with the drums. I know I'd have a hell of a time setting them up properly. But then I'd be afraid they were too soft when towing.
Dude...that was the **** :cool:
Huge difference between the drums and discs. It was like driving a race car :redneck:
I didn't mod the master at all, just calipers, brackets, rotors, wheel studs & brake lines...just an afternoon of fun :flipoff:
I don't think they make the brackets for mine.. atleast I've never heard of it.. And I thought all of them used half ton front calipers for the rear? Never heard of the 3/4 ton ones being used.
CrustyJeep said:
3/4 ton rotors on there Brad?
I'd have to stick with 1/2 ton I think to fit in my 15" wheels.
Depends on your wheel pattern. I used the 3/4's cause I needed the 8 lug, the wheels were 16.5's I think.
You may have to grind the outside of the calipers to get them to fit a 15" rim....nothing uncommon
The difference between the chevy 1/2 & 3/4 ton front calipers is like a 1/16" to 1/8" inch in the piston diameter.
My rig has the 3/4 ton 8 lug stuff on my rear 60...
My rig has 15" rims...
Just do a little fit, spin, and grind the casting flashing as needed...
Glen,
Why limit it to the 15 inch rims? Candidly, now would be the time to consider upgrading the whole axle to a 60 or 14 bolt. As factory disc braked rears are becoming more prevalent, you should be able to wrecking yard shop for a suitable replacement, and swap everything - gears, shafts, brakes - all at once. Yeah, you'll eventually have to get rims and tires (and swap over the front too, eventually) but the rims can be bought cheap as new-take-offs, and eventually everyone needs tires.
Tony
TreeClimber said:
Glen,
Oh I know, I know... But the front end had to be rebuilt from the ground up, so that sucked up the dough. I already opted for 6-lug front conversion rotors, so it'll have to stick for a few years. I didn't want the extra expense of a rear axle (that I would rebuild), plus wheels, plus tires.
CrustyJeep said:
I think about drums in my sleep. The beauty and simplicity of drum brakes often brings a tear to my eye.
Then why exactly do you even want rear discs or the tow rig.
Buy a Schmuckies set of lifetime warranty shoes, and be done with it.
