rear mounted radiator Qs
what was the point of drilling an 1/8" hole in your T-stat? was it to increase the flow of the cooling system when the Tstat is shut?
i just found a Tstat housing i had off of my 85 and it happends to have a temp sensor mounted right on top of the stat housing so no need to drill and tap my other one:D
The reason to drill is to let any air bypass and rise to be removed from the system. If I remember right, the factory stats had a bypass dingle already...
