Cascade_Crawler
Roughly how much would it cost to get a drivers drop front axle retubed so it would be a pass drop? Who can do it?
So what's all this talk about driver's side stuff... I thought you were going to pick up a chevy 60 on Sunday... ???
It cost me about $2000 to retube a front 44 for the rear.
MM251. Did the job all by my lonesomeTypo I hope?
he used the axle as an excuse to buy the welder! NO, it's not a typo!Typo I hope?
I just have to do about ten more axle housings and it will pay for itself :flipoff:he used the axle as an excuse to buy the welder! NO, it's not a typo!
You don't have to literally retube it. You can chop the long side off and splice it on to the short side. You just need a bitchin' welder
Bumping this as I'm thinking about it. I have a HP kingpin Ford 60 that I want to retube to passenger drop, and I want to run stock length shafts on both sides.
The 60 knuckles look like they will interchange easily from side to side... so it would a simple matter of lopping the C's off on each side in the same spot, swapping them side to side, sleeving the inside with some tight fitting tube, lining everything up, chamfering the surfaces where the tubes meet, and firing up the 220 mig and laying down some good beads.
Does this sound even remotely reasonable?
Or maybe I'll just take it to S&N so it gets done right. :awesomework:
The sleeve isn't where most of the strength comes from, by the time the axle tube is welded it is considerably stronger than any sleeve will ever be. If you are going to be relying on the sleeve only to align an axle you are crazy.
