YOUNG
Rockwell pinion brake brackets $35.00. These brackets are designed to use a Wilwood 4 piston caliper and a vented rotor. The caliper is mounted down LOW and doesn't cause any clearance issues. Below is a pic of the complete kit (which I can sell or give you part numbers for the rotor/caliper when the brackets are purchased) to give you an idea of what it looks like. The complete kit contains ALL grade 8 hardware, nylocks and brand new rotors and calipers. The brake kit can also be mounted on either side of the axle depending on your preference.
