Sold/Expired ROGUE Alpha air/hydro tubing bender, $595 with 1.75 or other die set
New product!
1.75" diameter roller pressure die!
If you are tired of having your pressure die flip or you want to have a nicer surface finish on your bent tube, you should swap your pressure die (right in image) for a roller die (left in image). This makes no changes to the alignment in the machine. These are CNC machined here in Oregon out of high quality US made Kaiser Aluminum.
$49, we have them in stock and ready to ship now.
https://www.roguefab.com/product.php?id=174
price on bender with 1.75 4.5clr die and 1.75 diameter pressure roller die, shipped to 35976
New die set! 1.00 square on a big 6 inch radius. $299 shipped anywhere in the lower 48 via FedEx with tracking and insurance. In stock now and shipping the same day you order by noon PST!
This bad boy will bend 1/16" wall cheap square steel tubing. It lightly wrinkles the inside wall, which is typically not a big deal on square tube. Most benders that bend thin square tube push the inside wall halfway into the cross section to avoid the wrinkles, but that isn't as strong.
We pushed the limits and bent some .059" square tube also. Pics of that super thin tube:
https://www.roguefab.com/product.php?id=177
New Product!
Awesome carts for our tubing benders. These are available fully welded and powder coated, and are full of the very best features like:
Heavy duty ball bearing drawer slides with spring closures
Haavy duty ball bearing casters with locking 5" wheels
Heavy steel construction (these weigh about 100#!)
Massive load capacity
Dual drawers for storage, rated at 100# each
Hooks for wrenches (3)
2 Die racks
2 die block shelves
locks and clamps to secure bender
Every part is made in the USA except the nuts/bolts/wheels. Even the drawer slides are made here!
We offer them in 4 levels:
ELITE ($695)- Just as shown. Durable hammered powder coat finish over meticulously prepared bare metal.
ELITE weld together ($545)- As shown, you weld everything together.
TRADESMAN ($395)- same as elite, less the drawers, upper shelves, and die racks. Comes painted.
TRADESMAN weld together ($295)- same as elite, less the drawers, upper shelves, and die racks. You weld it.
Production run of welded/assembled bender frames ready for sandblast and powder coat. Many of these will be sold as part of our elite packages https://www.roguefab.com/category.php?category=Tubing_Benders or call us at 503-389-5413
Made with pride in the USA. Not just assembled here either. Made on american equipment from domestic steel and raw materials to our designs and then tested assembled and packaged here. And our boxes are made here. And the cardboard stock that our boxes are made from is made here too.
Even the laser cutter. It is a 2015 Cincinnati.
We have wrapped up the electric hydraulic upgrade!
It is available 115/230V, and comes with a full 2HP motor and double acting cylinder and valve. Many other bender companies are selling off-the-shelf auto lift powerpacks that are only one directional. The best thing about this system is that it has 195 degree adjustable auto stops! We just shot a video of them last night. We will be editing and uploading it shortly (its alsmost half a gig for just one video, it may take a while).
Here are a couple shots, click on them to check pricing and options on our web page. This is not a made-in-China system either. The cylinder is made here in the USA, along with the power unit and many other parts. The valve is from Europe and the motor is non-US North America. The parts from the pacific rim can fit in one hand (a few switches).
Link: https://www.roguefab.com/product.php?id=202
