London Gentleman
How would a 6" wide rim act on 12.5" wide tire? Ballon? Blow beads? Tell me please!
Thats what I like to hear!
But they would be stock toyota steelie's, would be way rad. :awesomework:
How would a 6" rim on a 12.5" tire be different than a 7" rim on 14" wide tires? What makes it "bad"?
yeah those boonie... :stirpot:
im running stock chevy 16.5x6.5 wheels with a weld on beadlock kit..with 42x14 iroks...and they are more rounded profile on the skinnier wheel when aired up,but at 5-8 psi they work great!
Hi All:
The tire shop will tell you that a 12.5 inch wide tire should go on a 8.5 to 10.5 inch wide wheel. From my personal experience a 7 to 8 inch wide wheel works just fine; a more narrow rim helps to hold the tire bead better while aired-down.
Now, IMHO a 6 inch wide wheel should not be used on tire wider than 10.5 inches.
Regards,
Alan
Generaly the wider the tire the taller the tire. Meaning more side wall to flex when squeezed on to a narrow wheel.
Im running 19.5 wide boggers on 10'' wheels. No problems yet. They ballon some when you fill the tires to proper street air presure. But i use them offroad only N they stay between 4-10 psi.:awesomework:
Could you get a pic of the balloning thats accuring at street pressure?
