gasman
Re: ***2011 Built Rail Buggy Buick V6***Cash offer need room
You are mistaken it's an older model car transmission pre '66. Actually on the closed axle the only difference between a bus and car are the gear reducers on the end of the axle. It's the same transmission just the ring and pinion is flipped and the gear boxes reduce the gear for the bus. A lot of the drag racers use the closed axle and claim it's stronger to build for the strip, but for off-road it's limited to its suspension travel. Back in the day everyone run these and they are pretty tough but they have a small reverse gear and won't last under a lot of power. Chadslytowncrawler2 said:Unless I'm badly mistaken that's a bus trans..... Wich is good. Tuffer than car trans
Glws
