GT_Buggy
My old GT Buggy is for sale minus engine, transmission, tcase. All you need to do is add your power train and go ride. Here is CL listing http://atlanta.craigslist.org/sat/snw/5026859930.html -Hardline Price $4,300 firm.
This buggy is set up for a big block Cadillac 500, power glide, NP 205. It will fit most every combination of engine transmission and Tcase as I have run several combinations of TH350s, TH400s, NP 208s, NP241s. 121" wheel base 22" belly pan. Everything else is intact. Here is what you get.
- 4 - 44x18x16.5" cut Boggers bead locks with Total metal innovations DIY bead locks with inner rim stiffeners. These have been run for one season. Have some wear but overall in great shape. See pictures for tread. - 1 -- 44x19.5x16.5" non-cut Bogger on matching DIY beadlock. 1 - 44x19.5x16.5 bogger on steel wheel (no beadlock) (I have $2,600 in these tires and wheels)
- Cage -- main cage is 1-3/4" DOM. There are some sections that are old tube original to the Buggy that are not DOM but main cage is DOM . Buggy has been rolled once on the new cage and does not show any deformation.
- Suspension -- Leaf spring with shocks. This has worked great for me for over 3 years. One leaf spring is bent and has been that way for 2 years. Buggy has great flex for leaf springs and can do almost any trail at Morris Mountain or choccolocco offroad park. Traction bar on the rear. Check out my youtube page for the some of the videos
MMORV - Rock and Roll https://www.youtube.com/watch?v=lQfNZYuQdQU
MMORV - Loop springs - https://www.youtube.com/watch?v=sh16z_Bl8NE
MMORV RBD - https://www.youtube.com/watch?v=n5vOTdK5Zjo
GAP - https://www.youtube.com/watch?v=MVXJuSFaXvw
- 8000 pound Warn Winch and controller. (needs to be rebuilt)
- Axles
-- Front passenger drop Dana 60 with Detroit locker, Stock 30 Spline inners, chromoly 35 spline outers with drive flanges. New Wheel bearings replaced in September( I have pictures if you want to see). Since I upgraded to the 35 spline outers I have not broken a single axle. Before the upgraded I broke several stock outers. Spicer universals ½" metal front diff cover. (I have $1,500 in this axle in parts)
-Rear Dana 70 with 35 spline axles Lincoln locked. Never broke anything in this axle. Tube rear diff cover.
Steering -- Come with full hydraulic steering gear box, single ended ram, and all the steering lines. It comes with steering wheel.
- Comes with, 2 lights that were working when taken part, 2 plastic racing seats, wiring box with all the wire and relays you need to run, switch box, and trans gauge, water temp gauge, Oil pressure, gauge RPM gauge.
- Comes with dual fan radiator that kept my big block motor happy at all times. Great cooling for any engine.
- Comes with front drive shaft set up to run a flanged np205. 1350 on the front drive shaft.
-1985 chevy disk brakes on all 4 corners.
- comes with everything you see in the pictures in side the buggy. All the mounts, shocks, springs, tubes, coolant hoses, steering hoses, gauges, wiring.
Call (no texts I don't have text messaging unless you can use imessage i have an iphone. Work wont let me have txt on work phone) Anthony 678-300-7469 with any questions. Ready to help you put on your trailer and drive away. I have a winch and a truck that we can use to load it. Message me with any questions. If someone wants the axles and someone wants the tires that is the only way I would separate.
I have a spare np241 and an sm465 if interested as well. 241 came out of the buggy awhile back and the 465 was off a buddy's buggy
- Axles
