toofast070
Anyone running the solid brand 40 spline otters?
Pros and cons?
Any other brand that someone would recommend ?
Pros and cons?
blacksheep10 said:Not that much money, I'm probably still a dealer and was thinking about them when I still wheeled. Depends on if you're breaking stubs or joints. If you're not breaking joints you probably have CTM or something, and if you have that, just get teh stub and not have to get bigger spindles, bearings etc to make a 40 spline stub fit and still have a 60 joint.
kboring said:IMO - Id rather have a stub shaft as a fuse to break before I get my inner shaft, R&P etc.....I run 4340 35 spline yukons and am just about guaranteed to break one every trip. Easy to change and a cheap fix compared to the other options
Dammit man! Personally I would rather have my d/s joint as a "fuse". So much easier for me to fix.. Just bring a spare shart and swap it. But man I got 1310 joints on d/s ., stock gm 60 inners, spiced joints, and yukon outters.. Knock on wood I ain't broke **** in the axle. I know I don't have 700 hp, and I dont go riding only To try and destroy my **** I have worked so hard for... But at the same time, there's always several occasions where The last thing on earth that I want to do is have to go down the hill backwards, so I'll have to hold it on the floor.. I'll mash it when needed, and usually don't have a problem doing most all the trails where ever we ride .. But DAYUMM what the hell Yall Doin to break **** so often? Lord I would be so frustrated if I broke **** a lot .kboring said:IMO - Id rather have a stub shaft as a fuse to break before I get my inner shaft, R&P etc.....I run 4340 35 spline yukons and am just about guaranteed to break one every trip. Easy to change and a cheap fix compared to the other options
If you have a hp 60 with 4.88 or higher gears the only custom thing you would have is inner shafts stubs would be standard as well as the bells. Your front end wouldn't be the weak link!kboring said:Yea its a HP60 center with Reid Chevrolet knuckles - 66" WMS.
Goes between the fenders on my trailer
