fomoco365
I believe I broke the Powertrax locker in my front axle yesterday. I am wondering if I could run a spool in the front without snapping axles left and right?
this^^^. especially with longs and assist, i wouldnt worry about it... matter of fact i would probably weld an open diff (im a tighwad!).30th6 said:I'm runing a welded front,i broke a stock birf but upgraded to 30 spline longs and cromo hub gears but haven't had it out.to make the turning easyer you could leave one hub unlocked until you get on some rough stuff and then lock in the free hub.
Sent from my DROIDX using Tapatalk 2
yes you are and be sure you don't do like Potts done the other night to his dana60 rear diff ill let him say what he didmikepotts said:this^^^. especially with longs and assist, i wouldnt worry about it... matter of fact i would probably weld an open diff (im a tighwad!).
no biggie! im taking two rear 60's and using parts from both to make a good one, the housing i am using had a trac lock and was from a 79, the other one had an open which i welded so i could use it... after welding charlie mentioned to me he noticed it has coarse splines (evidently and earlier 60), so now the axle shafts from the 79 wont work with the carrier i have welded... BUT, ive already found a pile of early rear 60's at P.A.P. nashville where i will be next week, so i can get some shafts to match... when i regear (later) im gonna get a spool so i will get the proper one to work with the 79 shafts i will have on the shelf.fordcontraption01 said:yes you are and be sure you don't do like Potts done the other night to his dana60 rear diff ill let him say what he did
ive always welded mine fully to the carriers too.BUG-E J said:I had to run spools in my yota axles. Busted EZ lockers. Then split the carrier in half and no the spiders werent welded to the carrier just each other. Spools were the only thing that would hold up. Usually much cheaper than a stock carrier too.
mikepotts said:ive always welded mine fully to the carriers too.
maybe ive just had good luck... i usually just buzz it all till im done and let 'er eat! i actually had a 76 waggy with a 30 front 44 rear, i pulled the covers, clean with brake parts cleaner (not recommended) and welded them up in the housing! refilled with oil and wheeled the piss out of it! welded rockwells, ford 9", 7.5 and 8.8's... never did anything special, never had trouble with warpage or breakage... like i said though, maybe ive been lucky. you know the saying, "id rather be lucky than good".BUG-E J said:I always heard that would heat the carrier and make it weaker or warp it.
