bamatoy
- Joined
- Apr 1, 2011
- Messages
- 574
. Well running a Detroit its nothing like being welded, it unlocks without a load, a selectable locker (arb/ electric) are exactly like being welded. Selectable lockers only unlock when tuned off, but both wheels pull ALL the time when turned on.Stu said:The shitty thing about welding a Toyota is that birfields and longfield are a wear item. When your welded, drivin around puts a LOT of wear on them. I got one of the first sets of chromoly longs back in the day and broke 6 or 7 of them running a Detroit, which is about the same as welded. Went to a selectable 3 years ago and have only broke 2 since and I drive a LOT harder than I use to.
I have run welded rear thirds for years with zero problems stock axles, did although break 2 r&p's and 1 rear axle. I run this setup for about 8 years , but never a problem with the carrier.
That being said, I recommend welding a rear but the front does have some wear items, and I don't like the thought of having them doing extra work when not needed.
